Chipper Engine Runs, loses RPMs then revs back up
Old 06-26-11, 01:04 PM
doc
doc is offline
I have a, well, rather old, 8 HP Troy Bilt chipper/shredder. Briggs engine. It starts up fine, runs a bit, then loses RPMs, then revs back up. It does this about every 2 or 3 minutes on a bad day.
I had a local guy look at the problem a while back - he says he rebuilt the carb and replaced the fuel line and a few other standard tune-up things. It fixed the problem for about a year and now its back.
Any ideas out there? This is a fine machine but for this perplexing problem.
Old 06-26-11, 01:40 PM
Post the engine model, type and code usually stamped in the engine shroudd just above the spark plug. Have a good one. Geo
Old 06-26-11, 03:19 PM
doc
doc is offline
Model: 190412
Type: 3140-01
Code: 90092810
Old 06-26-11, 03:27 PM
cheese's Avatar
There is a screw coming out from the bottom of the carburetor bowl. Try backing it out 1/8 turn or so.
Old 06-26-11, 03:48 PM
doc
doc is offline
Thanks! I'll try that tomorrow and report back.
Old 06-27-11, 05:05 PM
doc
doc is offline
Turned the screw and it seems to have worked. I'll know more when I run it tomorrow for a longer period and put some load on it.
Thanks, Cheese!
Old 06-27-11, 10:29 PM
cheese's Avatar
Great! Thanks for the update!
Old 06-29-11, 06:24 PM
doc
doc is offline
Last update (I hope) - used the chipper for an hour today and it ran like a charm. Thanks so much cheese!
Trackbacks are On
Pingbacks are On
Refbacks are On
