problem with Walbro carb with fuel Solonoid
Retrocede's Avatar
NY
06-27-11, 05:59 PM   #1
I have a Kohler 16 OHV on a LT1000 mower. It has a Walro carb with the electronic fuel Solonoid. Engine runs fine for about 20 -30 minutes, then stalls out. It will restart but will only run a few minutes. Not sure if this is a bad solonoid, fuel filter or what. when it cools down, it will run for another 20 minutes or so. Any help will be greatly appreciated.
Thanks,
Retrocede
geogrubb's Avatar
MO
06-27-11, 07:57 PM   #2
Posted By: Retrocede I have a Kohler 16 OHV on a LT1000 mower. It has a Walro carb with the electronic fuel Solonoid. Engine runs fine for about 20 -30 minutes, then stalls out. It will restart but will only run a few minutes. Not sure if this is a bad solonoid, fuel filter or what. when it cools down, it will run for another 20 minutes or so. Any help will be greatly appreciated.
Thanks,
Retrocede
When it starts to die remove the fuel cap to see if it will continue, maybe the cap isn't venting properly. Have a good one. Geo
38racing's Avatar
CANADA
06-28-11, 07:02 AM   #3
look for any crap in line from tank to carb that could reduce fuel flow. If gravity fed just pull line off carb and check flow rate. Had a Kubota act like that , had crap in the filter/shutoff assembly.
