New Briggs and Stratton motor on old snapper...ISSUES. PLEASE HELP!
Hello.
I recently threw a rod on my old Snapper. I replaced the motor with a new B&S PowerBuilt 17.5 HP engine. After installing, (and filling with oil) I tried to crank it up. In my haste I had forgotten to activate the pressure switch in the seat. It turned over 4 or 5 times, turned slowly, and then wouldn't turn at all. I found out that I had apparently ruined my ignition relay, because if I jumped out the terminals, the starter would attempt to start the engine. I have tried turning the crank manually by twisting the drive plate/shaft with no success. The manual is of no help. Somebody please help me!!
-Justin
-Justin
Check the battery condition. If you don't have 12.5 volts or so when trying to crank, it's time for a new battery.
You can try to jump start it off a car battery. Make sure the car is turned off and the cables are hooked up correctly.
