Honda Harmony 215 Blade clutch is slipping
gjsullivan's Avatar
OR
07-05-11, 04:23 PM   #1
Honda Harmony 215 2 speed
I just replaced the 2 speed shift lever on the transmission.
I Had to remove the Blade brake, and pulley to get the belt off and on and get access to the top of the transmission.
Now that I have put it back together. The Blade is slow to spin up when I pull on the top handle to release the Blade Brake. It takes about 5 sec for the blade to slowly spin up. It cuts light grass fine but the Blade looses speed in heavier grass and comes to a stop.
I checked and the Blade Brake is fully disengaging and I can move the blade around easily by hand. It seems to me that it is with the cone at the top of the driven disk.
I think it may be the center bolt is not tight enough. I tightened the center bolt while holding the top of the motor. Is there a torqe spec for the center bolt ? I don't want to tighten it to hard and break it.
gjsullivan's Avatar
OR
07-09-11, 04:35 PM   #2
I figured it out. I was that the bolt in the shaft was not tight enough.
I had to put a screwdriver in the gap in the fly wheel to keep it from turning and was able to tighten it all the way.
To tighten it I avoided taking the starter pull and red cover off to get to the flywheel. I could get to it right behind vertical shaft for the governor. I was able to insert a screwdriver in the gap in the flywheel.
