Fl20 weedeater Fuel line replacement
After digging out my parents old weedeater to do some edge trimming i discovered that not only wasn't it drained of its remaining gas, but the fuel line seems to have a small hole in it (when priming it some bubbles start to form on the exterior). How do i or where can i find a manual that actually tells me how to fix it myself? Taking it to a repairshop is my last resort because they charge an arm and a leg, and I'd rather try to fix this one myself before going out and buying a new one.
You must replace the fuel lines, draw a diagram or take a picture of the routing before you remove the old ones, you can buy a fuel line kit at your local small engine shop, cut the new lines at a extreme angle then feed the point through and pull them with some pliers. Have a good one. Geo
