yard machine reverse cut off switch
Old 07-18-11, 07:20 AM
Hey, guys, I have a yard machine 15.5 hp Briggs engine and I'm looking for the cutoff switch for the reverse/blade turning safety. I have no fire at the plug so I disconnected the primary wire of the coil and got fire, so I know it's one of the safety switches that's bad. jumped the clutch and not it. disconnected the seat and that's not it so only one left is the reverse as far as I know but I can't find it.
Help!!!
Old 07-18-11, 08:26 AM
If it's the model with forward/neutral/reverse shifter in the middle and the Park speed on the fender then there might just be a metal tab switch that the forward/neutral/reverse shifter hits in reverse and it's just under that shifter cover. You say jumped clutch, but what about the blade pto switch?
Old 07-18-11, 09:08 AM
Thanks for the reply 38.My shifter is on the left side and the blade engagement is manual on the right side fender,though
