Throttle cable problem
I own a homelite weedeater, the throttle cable broke, purchased a new one and the cable is to short everything else is exactly the same. What can I do to make it fit??
Without knowing the model numbers and parts numbers etc, is it possible to loosen the trigger assembly housing and slide it closer to the engine giving you more room, also on some Homlites there is a slotted bracket on the housing to give you some additional room. Have a good one. Geo
