chainsaw will not cut straight
Received 0 Votes
I have a 268 Husqvarna that cuts to the left.I repaced the bar chain spocket and the new chain is worse.Tight or loose chain still the same.
With a new chain and bar, you either have hit something on one side of the chain, dulling the chisels on that side only or otherwise damaged the chain/bar, or you have a defective chain/bar. I don't see any other way it could be anything else.
Received 0 Votes
problem fixed
I checked the chain and one side was dull.Have picked up a chain sharpener on ebay for 50 dollars called dual power.After two atemps it now cut strong and straight.thanks for advise it made me go back to the start and it was the chain.
