Ryobi carb adjustment
Old 08-02-11, 03:52 PM
My Ryobi 2 cycle engine (30542) was has been running fine for years.
My teenage son claims it wouldn't 'stay running' for him, so he 'adjusted' the (I think) 'idle screw'.....in the rotating choke knob, there is a hole with a single phillips screw....It looks to be a 'idle' adjustment screw, since there's not two (meaning, L or H).....he turned it a number of times......and wouldn't stay running.
Usually, a shop manual will have you close the screw completely, and then 'unscrew' some certain number of times, to get you 'in the neighbor hood' of getting started.....Does anyone know where that starting point, (number of turns) is?.....
It will start, but won't idle..........
thanks!!......
Old 08-02-11, 08:11 PM
cheese's Avatar
Received 97 Votes on 90 Posts
The idle speed screw can be accessed through a hole in the black cover on the back of the trimmer. The screw in the choke knob has nothing to do with the idle. There is no "starting point", just turn it in until the idle speed is satisfactory.
Air fuel mixture screws have the starting points you're thinking of. Yours may need adjusting as well, but it could be a number of problems. The carb may need to be removed and cleaned.
