Belt adjustment for a 93 Murray 46 inch lt
Old 08-17-11, 02:11 PM
Is there any way to adjust ( tighten) the blade belt ( I am not a smart repair person. I have the right belt and it is on correctly. It is just a little loose and dropping off one of the inside pulleys. Is there any way to adjust any pulley to tighten slightly?
Thanks for reading.
Old 08-17-11, 03:59 PM
cheese's Avatar
Is it dropping off the pulley while the blades are going, or when you shut the blades off and then back on? Are you checking to see if the belt is tight with the blades turned on?
