Gear-Pinion on starter worn out
I have a Craftsman 17 hp, 42" mower electric start 6 speed transaxle lawn tractor(model 917.271653). I recently had issues starting it. After troubleshooting my electrical system I pulled off the starter and noticed the Gear-Pinion (693713) was worn down to practically nothing. I was wondering if it would be an issue just to replace that part or do I have to replace the whole starter? I also noticed the new part I was going to order was a steel gear as opposed to the hard plastic which was on my old starter. Is there a difference? I'm following the specs from my owners manual and it gives me the part # for a steel Gear-Pinion.
And oh ya.......I thought I read somewhere that it requires a special tool to change this part. Any help would be greatly appriciated.
If the gear is worn down, it is a problem. If the number is for a steel gear and yours is a nylon gear, then that may be the problem. The steel gear has a different tooth pattern and doesn't match the flywheel that is made for the nylon gear. Did you buy this mower used, or did it come new with the nylon gear?
I bought it new but did have a local small engine mechanic work on it about 3 years ago and I'm pretty sure he replaced the starter.
the couple 31 series 17hp briggs I've seen have had the steel gear on the starter
check your flywheel gear section with a magnetic and see if it's aluminum or steel
The ipl I have for 31 17hp says
693713 for steel ring gear
695708 for aluminum or plastic ring gear
I tried the magnet to the flywheel and the magnet stuck to it.. I also referenced the B & S Engine model # 310707 type 0137-E1. And the craftsman part # for the starter itself 693551 and both reference the steel ring starter. The part # for the gear pinion itself on the starter is 963713 in the owners manual. I found a starter on amazon for $30.78 for part # 693551. It has a steel gear I think i'm going to go that route. Any ideas?
You can change just the gear with a small flat head screwdriver and a small 3/8" socket if you want.
Replaced the starter with a $38 starter from amazon with steel gears, started first try...Thank you all.
