18.5 hp briggs intek
Old 09-17-11, 04:13 PM
Model: 31p777-0348E1
Fresh rebuild,how long to run it before putting a load on it? When I engage blades it makes a banging noise then smooths out.it runs great without any load
Old 09-17-11, 04:26 PM
cheese's Avatar
The banging sound is probably loose engine mounting bolts. If not, the rebuild wasn't done correctly. You can put a load on it pretty much immediately.
Old 09-17-11, 06:05 PM
Nevermind
I think the banging noise was the electric pto mounted wrong and rusted up from sitting awhile.is White smoke normal at blade engage,it's just a puff of smoke when blades are engaged
Old 09-17-11, 06:39 PM
cheese's Avatar
The white smoke could be due to rings not seated yet. You said "fresh rebuild". What was done? Was the cylinder honed?
Old 09-17-11, 06:53 PM
Yes cylinder was honed ,new piston and rings,new head assy,new conector rod,new push rods
