Ryobi CS30 won't run
Old 09-19-11, 03:16 PM
T
question. I have a ryobi cs30 that will only work with the choke on and as soon as I pull trigger it dies. I figured it must be carburetor so I purchased a carburetor from ereplacement site and it did not even start up. I put the original carburetor on and it worked fine. I figured it was a defective part so I RMA'd it and received a new one. Now the new one will not even work on the trimmer, but the old one still will start while the choke is on.
Any ideas?
Old 09-19-11, 04:31 PM
G
Received 24 Upvotes on 23 Posts
While the old carb is on and the trimmer is running, spray/dribble some brake parts cleaner behind the carb and along the intake mating surfaces, if the engine tempo changes you have an air leak. Have a good one. Geo
