Briggs and Stratton runs on full choke
Old 09-21-11, 03:10 PM
P
New guy here, great site. I own a sears rider with a B/S 20.5 hp
twin cyl, model 461707-0145-Ea motor. Starts fine and after 10-
15 minutes of cutting I need to full choke it or it will die. Have
replaced fuel filter, opened up the fuel tank cap, cleaned out
the tank, new fuel, sprayed cleaned in the top of the carb and
Cleaned the air filter.
What would cause it to need more fuel when it gets hot?
Thanks to all
Phelpo
Old 09-21-11, 08:10 PM
3
did you make sure the line from tank to filter/shut off is clean and shut off has no crap in it.
Old 09-22-11, 05:53 AM
P
yes and there is no shut off, this has been an issue for some
time, I had replaced the lines a few yrs ago.
what is the cost of a new carb?
Phelpo
Old 09-22-11, 07:21 AM
3
does it have the the anti backfire solenoid on the carb?
Old 09-22-11, 08:29 AM
P
that 38 I do not know, what does it look like? this mower is over 15 yrs old.
Phelpo
Old 09-22-11, 08:35 AM
P
I looked at sears diagram and it has a spark arrestor on it, didn't see
a anti back fire anything
Phelpo
Old 09-22-11, 03:09 PM
Received 30 Upvotes on 29 Posts
The spark arrestor would be in the muffler. The shutoff solenoid for back firing is on the carburetor bowl. It would have a wire running to it and would be battery fed.
Old 09-22-11, 03:24 PM
hopkinsr2's Avatar
Just for a goof, Try it with the fuel cap loose. If the vent in the cap is plugged, it makes them act as if they are running out of fuel after several mins running..... Roger
Old 09-22-11, 05:54 PM
P
I took the cap off totally and still it needed to be fully choked.
Old 09-22-11, 06:00 PM
P
how can the backfire solenoid effect the running of the motor
Old 09-22-11, 06:38 PM
It's a fuel shutoff solenoid. It blocks a backfire from coming back through the carburetor and creating fire hazard.
Old 09-22-11, 08:58 PM
cheese's Avatar
Received 120 Upvotes on 110 Posts
Sounds to me like the carb is still plugged up somewhere.
