engine shuts down under load
Received 0 Votes
I have a12.5 hp B&s engine on a craftsman riding mower about 10 years old. It runs fine but shuts down as soon as I apply any load. I have cleaned the air filter and spark plug, and sprayed carb cleaner in the intake with no result. I have adjusted the carb as far as the stops will allow. the engine stalls as soon as I take pressure off of the clutch.. Any good Ideas?? ED
Received 0 Votes
Well I beg to differ, but I have been wrong before. Either way, he can ride it for a lil till it does what he says, so I still believe it is a carb. issue. We need to see what he comes up with and go from there. Plus he wanted good ideas. Carb. rebuild.
Sure, it could have a carb problem, but the symptom here is pointing to seat switch. He doesn't say it can be ridden, he says "it stalls as soon as I take pressure off the clutch". This translates to "it dies as soon as the clutch switch is deactivated". When you let off the clutch, the kill circuit passes through the clutch switch and runs to the seat switch. If someone is on it, it doesn't kill the engine. Since edfndy says it runs fine, I would tend to not go tearing into the carburetor when the symptoms point elsewhere. After working on mowers 23 years, part of that for Sears on craftsmans like the one in this post, moderating this forum over 10 years, and running my own shop for the past 13 years, I've learned a couple of things and try to share them with others on this site. Sometimes I am still wrong. I will add that rarely does a newbie with 2 posts come in and make themselves welcome in your fashion.
Received 0 Votes
problem solved, I disconnected the seat safety switch years ago, and taped the switch button down. The tape wore out and released the button. After retaping the button the tractor ran well and allowed me to mow. Thank all of you for your help. ED
