MTD Snowflite 310-600A needs new tires
I purchased a used MTD Snowflite 310-600A K019B. It works great and throws the snow very well. The problem with it is the tires are very worn. Does anyone have a model number for the tires or other replacement options? They are tubeless tires, look like hard rubber, with 3.50-6 on sidewalls.
Received 2 Upvotes
You didn't need a model number in this instance. Go to your local small engine shop (or Tractor Supply if you don't have one) and pick up two 4.10x3.50-6 tires. If you buy Carlisle X-Trac or Sno-Hog tires you likely won't need tire chains. X-Trac being my best suggestion.
