Craftsman II Riding Mower won't start
Received 0 Votes
I have a Craftsman II model 917.254520 that won't start. When I turn the key nothing happens; every once in awhile like when I disconnect & reconnect something there will be one click when I turn the key. Starter does not engage though.
First I tried another battery that I know works--same problem, and I later found that my battery is good. I'm getting 12V to the solenoid. Tried to jump the solenoid with a screwdriver and nothing happend so I started more testing. When I turn the key I'm getting 12V to the other side of the solenoid and to the starter. I assumed I had a bad starter and purchased a new one. Same thing...no start. I bench tested the new starter and it works.
I assume the problem might be a ground somewhere but I'm not sure how I would test for this. Is there a way to jump from the battery right to the starter (i.e. where's the ground wire go)?
Basically you did just jump directly to the starter from the battery - you placed a screwdriver between the two heavy posts. Check your ground cable from the battery post to where it attaches to the frame of the mower; I'll bet you need to clean this up and you'll be good.
Actually, it would take several dollar bills folded in half to gap a spark plug sufficiently. It should be set at .030". Replacing a spark plug won't do anything to help an engine that the starter doesn't work though.
