Weedeater Featherlite XT200 won't start
After some years (5+) of totally reliable starting, my weed whip won't start. I found and replaced a couple of rotten fuel lines but still have the same symptoms. I notice that when I push on the primer bulb, it doesn't pop (or even ooze) back out. I sprayed a bit of carb cleaner into the carb and it'll run for a second or two before dying (obviously just burning up the carb cleaner) so I am guessing that it isn't pulling fuel. I probably have air in the lines (and don't know whether that is a problem). If I take the primer bulb off, it pops back out. I see a very thin black diaphragm on the underside of the primer bulb and don't see any tears in it. I did not replace the fuel filter that sits inside the gas tank.
I would very much appreciate any suggestions before I start buying replacement fuel filters, primer bulbs, carb repair kits, etc.
Thanks a million in advance!
David
David
Your carburetor likely needs servicing/cleaning and probably a kit, and the fuel filter may also need replacement. Can you blow through it? These things were $58 new at Walmart, and you may well spend that much trying to fix it and still not have it fixed. They're only rated for a few hours of use before their useful life has expired. Just a thought.
Received 2 Upvotes
Among the numerous parts included in a rebuild kit will be a screen. This filters incoming fuel as it enters the carb and I'll bet it is plugged tight. This would explain both the no-start and primer-bulb-not-returning issues.
Thanks for the advice. Yeah, I know it was only $58 and I have certainly gotten some good use from it - no complaints there. Its just one of those "I SHOULD be able to fix this" things...
