Chainsaw Issues
Received 0 Votes
Chainsaw Issues
Greetings all.
I'm having some issues with my chainsaw. The starter cord won't pull smoothly anymore. i took off the casing and cleaned and oiled it up a bit, and its still a rough, jerky pull. So needless to say, the chainsaw won't even start up with out a proper pull. Any advice would be greatly appreciated.
There's a chance it's in the engine and not the pull starter. Take off the cowling that contains the pull start - should be the four screws. Then turn the engine over by turning the flywheel by hand with the plug out. If it doesn't turn over smoothly the problem is either in the cylinder/piston or the rod bearing. If you find out that's the case, for that saw, it's better to replace the saw rather than fix it.
Sounds like problems. Usually I find this to be caused by bad crankshaft bearings allowing the shaft to move side-to-side, causing the flywheel to hit the coil. Not worth fixing on these saws. Wouldn't hurt to check pull rope operation with it removed from the saw, but there are no bearings at the rope spool.
