Starting a Makita DCS510 Chainsaw
I bought a Makita DCS510 chainsaw a couple of months, the manual says that there is a compression release, but it does not have one anywhere I can see. It's like trying to start 20 Hp engine by hand, trying to pull the starter jerks the hell out of my shoulder. Any tips would be appreciated. here is the Cold Start instructions from the manual:
Cold starting:
Move the combination switch (1) up (choke position). This also
actuates the half-throttle lock.
Pull the starter cable (2) out slowly until you feel resistance (the
piston is now just before top dead center).
Push in decompression valve (5).
Now pull it quickly and powerfully until you hear the first
audible ignition.
CAUTION: Do not pull the starter cable more than about 50 cm/
20” out, and let it back in slowly by hand.
Move the combination switch (1) to the central “ON” position.
Pull the starter cable again, quickly and firmly. As soon as the
engine is running, grasp the rear handle (the safety lock button
(3) is actuated by the palm of the hand) and press the throttle
trigger (4).
The half-throttle lock will disengage and the engine will now
idle.
The manual says it's for the Makita DCS 410 and 510 so I think this pertains to the 410 not the 510 that i have.
Thanks
Gregory
Cold starting:
audible ignition.
trigger (4).
idle.
Thanks
Gregory
