Can someone help me with a Tecumseh cross reference?
Old 11-09-11, 07:54 AM
I trying to replace a Tecumseh engine HMSK80-155699W with another available type of engine. Can someone help crossover reference with this? Maybe a Craftsman or B&S?
Old 11-09-11, 09:50 AM
puey61's Avatar
Why would you want to replace the best ever snow engine made with something else? What is your trouble? Is yours not worth a rebuild? Craftsman does not make any engines...or equipment...or tools...it's just a well known, highly recognized name the smart people at Sears, Robuck & Co. came up with. At least you did not suggest a China Freight engine!
Old 11-09-11, 04:15 PM
If you are trying to repower something Small Engine Warehouse probably has what you need, Small Engine Warehouse - Repower Outdoor Power Equipment
Have a good one. Geo
Old 11-10-11, 04:17 PM
The engine block is cracked and I can't find a replacement. Any ideas?
Old 11-11-11, 05:10 AM
As far as I know the block is not sold as a spare part. At that point you're looking for a new engine. Where is the block cracked? If it's in the lower oil pan area that can welded back but if it's in the cylinder, cam or crank bearing area then I'd toss the engine. The easiest would be to just replace it with the same or similar Tecumseh engine instead of trying to go with a different brand. I might save the coil and carburetor off the old engine as spare parts for the new one.
Old 11-11-11, 09:54 AM
puey61's Avatar
The block, I'll bet is cracked right behind where the starter motor mounts up. A new cylinder block is available, part number 35385, but you may have difficulty finding one. But, more importantly, how much internal damage has occured?
Old 11-11-11, 04:16 PM
What is the engine on? Maybe there is a sub engine. Have a good one. Geo
Old 11-12-11, 08:15 AM
puey61's Avatar
I'm assuming on a snow thrower, hence the model ID of the engine...HMSK80 = Horizontal Medium Snow King 8.0-horsepower.
Old 11-12-11, 09:08 AM
Sorry puey61, I didn't make my self clear at all, I meant manufacturer and model number of the equipment. At small engine you can put in the equipment and it will give you replacement engines. Have a good one. Geo
Old 11-12-11, 09:32 AM
Here is a piece of equipment that has the HMSK80-155699W as the original engine and the suggested replacement. Have a good one. Geo
Ariens 824E Snow Blower Outdoor Power Equipment Repower from Small Engine Warehouse
Old 11-14-11, 06:33 AM
puey61's Avatar
Don't go by that link geo provided, that aged Ariens would never have had an 8-horse...either 5, 6 or 7-horse. The website's information is incorrect.
Old 11-16-11, 08:23 AM
From the Ariens Co,
Thank you for contacting the Ariens Company.
This engine was used on our model 932101 (824E) manufactured in 2000-2002.
Thank you,
Jim Schoelles
Ariens Company
Old 11-17-11, 06:36 AM
puey61's Avatar
Yes, a model 824E will have an 8-horse engine. The unit pictured is a pre-1972 model, not an 824E.
Old 11-19-11, 09:55 PM
thanks for the info
I pulled the engine apart and the casing block was cracked by the connecting rod so I'm going to replace the block and the rod. Everything else looks good. Thanks for the help!
Old 11-21-11, 06:32 AM
puey61's Avatar
Inside an engine is not somewhere you want it to "look" good. You definitely want to measure everything to the thousandth. Even the slightest wear out of the allowed specification range will have you pulling the engine apart again.
