troy built snowblower
troy bilt model 31AE6GQ3711 will not go out of gear. the friction plate is not touching. Pulled axle and when I released the top gear and slid it away, the wheels moved freely. Then when I slowly slid the gear it stopped. Got a new gear, same thing, Help, it looks so simple, I can not figure it out
Received 2 Upvotes
You most likely have one or more needle bearings seized in one or more drive train gears. These are not available as a separate part through MTD, you'll want to find them at a local bearing supplier such as Kaman Industrial Supply.
