Craftsman snow blower bearings. Need part numbers
Old 11-21-11, 07:14 AM
H
I bought an older Craftsman 8/25 trac drive, model 768.8849. It runs great and all but I noticed it would only go forward and not in reverse. I opened up the bottom of the unit and noticed that when you put it in reverse that the hex shaft bearings were worn/broken allowing for play in the shaft, and therefore not making contact with the gears when you put it in reverse. I went to sears online and you can't make out the part numbers on the diagram. Called Sears Parts Direct and they used the same online diagram I did and they couldn't make out the part numbers either. Does anyone know the part numbers for the hex shaft bearings?
Old 11-21-11, 07:53 AM
A
Received 4 Upvotes on 4 Posts
The hex shaft bearing assy is 85504MA
AJ
Old 11-21-11, 08:06 AM
H
Thanks AJ. I appreciate the info.
