snapper snow thrower carburetor rebuild
Old 11-23-11, 08:59 PM
R
I have a snapper le 17 snow thrower model LE3170R with a tecumseh motor. the owners manual gives me two options of motors HSK600 and HSK840, fromt he looks of the carb and muffler it looks like HSK 600. The shop i brought it too is telling me 135 for a new carb because it stalls out when it hits snow.
I was thinking of rebuilding the carb or maybe looking around for a new one but I can not figure out which carb i need. there are no serial numbers on the motor like the manual says.
can someone steer me int he right direction?
she's not the best looking blower but she starts every time and she was my first in 1995.
thanks. or perhaps a guy i can send this carb out to be rebuilt.
Old 11-25-11, 09:46 AM
puey61's Avatar
Received 2 Votes on 2 Posts
Look again for the ID numbers on the flwheel shroud. They may be stamped or on a sticker. We can't help you without these "number".
Old 11-27-11, 02:52 PM
R
here are the numbers i could find. i don;'t know what they mean.
HSK600 1683S (D) 4110H
Thanks
bryan
Old 11-29-11, 09:45 AM
puey61's Avatar
The original carburetor part number is Tecumseh 632410B and if you are going to replace the carb then it will be 640098A which is $80-90, give or take. Most carburetors can be reconditioned but I cannot tell you if yours is a good candidate unless I could personally inspect it. BTW, the HSK is the model number of the engine, the 1683S is the specification number and 4110 is the serial (date of manufacture)...the 4 is the year (you have to guess the decade but yours is 90's so, 1994) and 110 is day of the year or the 110th day of the year 1994.
Old 11-29-11, 10:06 AM
lawrosa's Avatar
Super Moderator
Received 77 Votes on 69 Posts
Sounds more like a governer issue.
Mike NJ
Old 11-29-11, 06:58 PM
R
thanks puey.
how do i know if it is a good candidate. it's not leaking fuel, all the parts are there, and there are no dents in the bowl. it starts up and runs fine if i leave the choke open.
iawrosa- how can i narrow it down?
Old 11-29-11, 07:09 PM
lawrosa's Avatar
Super Moderator
Well what exactly is it doing? Do you need to choke it to keep it running? That would be the carb then.
If all is normal until you load it up I would look at the governor.
I just took my generator carb off today and cleaned it. Dirt in the needle. Would only run with the choke on. Would sputter with the choke off. This is because I run all the fuel out for storage. Probably dirt from the tank. I am going to put a filter on the fuel line one of these days.
Look at the governor linkage and make sure no broken springs, tangs, etc.
The probalem is if you dont know what its supposed to look like and where the springs go, it will be a guess.
Mike NJ
Old 11-30-11, 09:39 AM
puey61's Avatar
A bad governor will not cause the carburetor to run better on choke, so you can disregard that. Any time a carb must be run on choke (I'm assuming you meant to say "leave the choke closed") indicates you have a restriction within the carb. Pull it off, soak it in a good bath cleaner and rebuild it with Tecumseh parts. I'd like to give you a rebuild kit part number but this carb, for some unknown reason, doesn't list a kit. You'll have to use individual parts.
Old 12-12-11, 07:44 PM
R
what do i use to give it a good bath cleaner?
Old 12-13-11, 06:20 AM
puey61's Avatar
We use NAPA's carburetor cleaner and it works very well. You can buy a gallon of it which includes a basket in order to place your disassembled carb into. If your carb has a plastic fuel inlet fitting do not soak for more than 15 minutes at a time. In other words, soak fifteen, spray off with a good spray carb/choke or brake cleaner, allow to dry (compressed air is best) and then repeat process as many times as necessary to remove all varnish from on and inside carburetor.
