Tillotson Metering Spring
Old 12-01-11, 06:39 PM
James Sanders's Avatar
Working on an old Dolmar 112 from 1987. Tillotson HK-21C carburetor. Rebuild kit didn't include metering spring. Need the metering spring, and cant find any parts lists online. anyone know a part number I can order for the metering spring?
Thanks
Old 12-02-11, 07:10 AM
P
Received 1,851 Upvotes on 1,657 Posts
A quick online search shows you are not alone. It seems there are a number of people looking for that spring. I don't know if the parts will fit but almost all the parts are available for the Tillotson carbs. used in kart racing. Check this page to see if they have what you need. Hopefully a engine guru will chime in with a supplier.
Old 12-02-11, 09:41 AM
puey61's Avatar
Received 2 Upvotes on 2 Posts
Because the spring used will be specific to the individual carburetor/application, we will need the model and serial numbers of the carburetor.
Old 12-02-11, 09:51 AM
HK21-C Tillotson
It appears that dolmar might still be selling it in a set, with the inlet needle 957150060, i'm going to try and order it
