WI
MO
12-07-11, 06:10 PM
The bowl nut(main Jet) is probably still clogged, there several styles with from 0 to 4 holes, the tiny one near the top threads is usually the problem, I clean it withe the wire from a twist tie. Have a good one. Geo
http://i190.photobucket.com/albums/z...c_bowl_nut.jpg
WI
12-07-11, 06:57 PM
Thanks for the reply.. used a twist tie and pipe cleaners ! its got 2 small holes and one large in center, none of the jets are adjustable like on the others I have worked on ?.. does the float pin ride on the float tab or go around the tab ? only thing I have not tried.. these motors are so basic... its driving me nuts... customer's blower too, Thanks Geo
MO
12-08-11, 08:58 AM
Posted By: Bman1958 Thanks for the reply.. used a twist tie and pipe cleaners ! its got 2 small holes and one large in center, none of the jets are adjustable like on the others I have worked on ?.. does the float pin ride on the float tab or go around the tab ? only thing I have not tried.. these motors are so basic... its driving me nuts... customer's blower too, Thanks GeoMay I suggest checking the bowl nut again, the tiny hole near the top is almost invisible on some. Refer to the pic below. Have a good one. Geo
WI
12-08-11, 06:37 PM
Ok put the inlet needle clip around the float tab.. figured that would take care of fuel issues.. also cleaned little hole in main jet as suggested... still runs 10-15 seconds and pops out the muffler and dies... on full throttle... would bad spark plug do this ? figure it would not run cold with bad plug.. or how bout old oil ? could the magneto be bad ? Im out of options
NY
12-11-11, 01:26 PM
The fuel system consists of more than the jets! There are passageways inside the carburetor that can and will clog up. How, specifically, did you "clean" your carb? When you had the carb disassembled how did the body of it appear? Any ethanol etching noticed? Another problem is that you have a bang out the exhaust and this, generally, indicates an ignition system breakdown. Do you have an inline spark tester to watch while you run the engine?
WI
