Poulan chainsaw issues
Received 0 Votes
I have a 8yr old poulan 2150, it runs but after running for 5 minutes while cutting the saw starts to cut out, it will restart i just can't keep it running (while cutting)... i did adjust during summer (H/L) and it ran fine but now that the temperature up here in NE drop below 45 degrees it's giving me problems again....
Any ideas...??
Any ideas...??
Could be a number of things. If backing out the H screw a little doesn't help, check the gas cap vent. It could be blocked. There could also be problems like a cracked fuel line, primer bulb, carb restrictions, or air leak in the case.
Received 0 Votes
I have the same problem described by "soccer34". I replaced the fuel lines, as they disintegrated, and verified they are correct. After I replaced the lines the tank became pressurized after pressing the primer a few times but that has since stopped. If I remove the plug and squirt starting fluid into the cavity the saw will run briefly and then stop. Any suggestions are appreciated.
Tom
Tom
Received 0 Votes
Yes, I have rechecked and the fuel lines and they are correct.
I read a post where someone mentioned they were getting too much gas and it was causing it to flood.
I checked and the lines are not crimped or pinched.
Thanks, Tom
Thanks, Tom
You mention seeing a post about flooding. Do you think your saw is flooding? If so what is it doing?
