John Deer LTD 155 draining the battery
jrp11948's Avatar
MD
01-11-12, 12:16 PM   #1
My JD wouldn't start so I replaced the selenoid. That fixed the starting problem. Then, I thought the 3 yr old battery was dead so I replaced it. One mow and the battery was dead again. Something is draining the battery. My first thought is to replace the starter. Since it's 12 years old I also thought to replace the wiring harness. Any thoughts on what it could be?
goldstar's Avatar
OH
01-11-12, 07:31 PM   #2
You need to test the electrical system to see if the battery is being charged when the engine is running. You also need to check for discharge when the engine is off.
Wiring harness and starter should not be a problem.
I think that your model is an LT155, not LTD 155, but I've been wrong before.
Woody
You can trust your car - and a whole lot more - to the man who wears a star.
cheese's Avatar
GA
01-11-12, 08:39 PM   #3
Replacing the starter and harness will only remove benjamins from your wallet. Charge the battery and disconnect the negative cable. Connect a test light from the negative post to the negative cable. If the test light comes on with the mower key off, then there is a short or drain on the battery. Unplug various things until you find the item that makes the light go off. This will narrow the problem down.
"Who is John Galt?" - Ayn Rand (Atlas Shrugged)
God bless!
jrp11948's Avatar
MD
01-19-12, 01:35 PM   #4
Lt 155
You are right, it's a LT 155. fingers don't work sometimes. Thanks for the responses, I'll try it. Always hard trying to find electrical problems.
