Craftsman 7.0 Power Washer removing water pump
Old 01-12-12, 07:36 PM
T
I have a power washer where the water pump has locked up. How do I remove the water pump to see if we can use lime away and free it up? It was started up with the water not hooked. I think this caused the water pump to seize up. I can't find any manuals or instructions on how to remove and check this pump This is a 2900 psi unit
Thanks
Old 01-12-12, 08:07 PM
cheese's Avatar
Received 153 Upvotes on 140 Posts
What model is it? Craftsman has a whole lot of different pressure washers.
Lime away won't do anything to free up a pressure washer pump that seized from overheating. It will need to be replaced.
Old 01-13-12, 10:01 PM
R
On my Cman 2600 psi (Honda GCV 160) I'm pretty sure that it has a sealed pump. I've heard those can not be taken apart but would instead need to be completely replaced should they fail.
Old 01-20-12, 07:56 PM
T
It is a craftsmaqn 7.0 hp model # 582752410 Thanks for the help. Are these pumps easy to get to and remove?
Old 01-20-12, 09:13 PM
cheese's Avatar
That number is no good according to sears. Double check it, I think you are missing something.
I don't know which pump you have without the number, but usually they are just bolted on and will come off easily.
Old 01-22-12, 03:32 PM
T
oops the model number is: 580752410
Thanks
Old 01-22-12, 09:58 PM
cheese's Avatar
You should be able to see the 4 bolts holding it onto the engine. Take them out, pull it off. That's it.
