B&S engine replacement
I have a blown 28R707-1120-E1. On my local craigslist someone has a 289707-015401-01. Will this work as a direct replacement?
Check crankshaft length and diameter, if they are the same, they should be interchangeable. There may be a difference in throttle/choke control, or electrical plug ins, but those can be swapped from the old engine. The bolt pattern should be the same. Both are electric start.
