Yard Machine 46" blades turning when PTO is off (startup and all the time)
Received 0 Votes
Model# 13AN771H729-manual is no help. This riding mower starts and immediately the blades engage, I turn the pto on and they move faster, but why are they starting up before I even turn the pto on? Should I try wd40 on the left side brake bracket or ? I just had the blades replaced and the fella said that i needed a brake pad, which he did not offer to put on, as this mower has been nothing but a headache since i purchased it. There is also a spring that goes from the brake bracket to ??? Thank you for all your help.
The missing or worn out brake might be the reason the blades are turning. The spring should put the brake on to stop the blades when they are tunred off. That might also be the reason. Without looking at it, I can't say for sure but it sounds like you already know of 2 problems that need to be fixed. Look in the back of your manual where it shows the parts breakdown of the deck. It should show you the spring and where it goes. It might be the only reason for the problem.
