John Deere ride on mower L120
Received 0 Votes
John deere ride on mower l120 bettery is ok but engine just grinds. Do i have it in the right gear to start
Hello DORBLAK,
From your description it sounds like you have a stripped starter gear or flywheel ring gear, Without engine model numbers posted it's difficult to give exact details. If you can remove the flywheel cover, This will let you look at the starter and ring gear teeth.
Good Luck
Good Luck
