Adjust valves on 18 HP Craftsman
Old 03-26-12, 05:46 PM
R
I have an 18 hp Craftsman LT mod # 917.273404. It will hardly turn over alone. When I turn fly wheel it will try to spin, then after a couple of turns it will take off and start. Another post had the same problem, and he was told the valves needed adjusted. I never found any thing else on the subject. I looked in older posts but couldn't find any thing. If any one knows how this is done in a simple procedure, I would appreciate the help. Thanks in advance
Robertk
Old 03-26-12, 06:06 PM
cheese's Avatar
Received 122 Upvotes on 112 Posts
You'll need to adjust the valves to solve the problem.
Old 03-26-12, 06:58 PM
31YTech's Avatar
Hello Robertk,
This should cover your request;
Good Luck
