Briggs 4HP - New Diaphram and Priming Bulb - Will not Prime
Received 0 Votes
I have a 4HP Classic and replaced the diaphram, priming bulb, and fuel filter screen
It will not prime. New bulb right one no doubt. Same for all parts right ones no doubt. The gas will not prime up. The carberator is secure to the tank. I cleaned the carberator jet too. Snaped it back in.
Need some good suggestions to try.
Hello glassc,
Did you put the diaphragm on the tank first then the gasket followed with the carb ?
If so take a look at #11 in this diagram and make sure it's not stuck/gummed up;
Disassembly, Cleaning and Repair of Briggs and Stratton Tank-mounted Pulsa-Prime Carburetor
Good Luck
Good Luck
I was thinking of the check valve as well. Here's a trick I've learned over the years for that problem. Take the tank/carb assy off the engine, make sure there is sufficient fuel in the tank. Tilt the carb so that you can put gas into the opening at the top of the carb, and have enough settle in it to cover the priming port behind the primer bulb. Press the primer several times, making sure you keep the fuel level high enough in the carb to keep the port covered. This will suck gas into the primer bulb no matter if the valve is stuck or not, and it will flush gas back and forth through that valve and quite often un-stick it.
