Cub cadet LT1045 not starting
Old 04-06-12, 07:53 PM
Im trying to get my riding mower started and no luck. I have tried the following:
1. Cleaned carb
2. Changed fuel in gas tank
3. Blew out gas lines
4. Changed gas filter
5. Checked to make sure I'm getting a spark
6. New spark plug
It will start and run on starting fluid and will run a minute or so. Not sure what else to do. Any suggestions?
Old 04-06-12, 09:23 PM
cheese's Avatar
Received 131 Upvotes on 121 Posts
Is there fuel in the carb bowl? Does the fuel shutoff solenoid work? What engine do you have?
Old 04-08-12, 11:31 AM
Yes, fuel in the bowl. It has a Koehler engine. Don't know what the fuel shutoff solenoid is? Is that under the bowl? How can you tell if it's working?
Old 04-08-12, 06:32 PM
cheese's Avatar
Yes, it's under the bowl. It should click when you turn the key on if it's working. If not, it needs to be worked free and cleaned with carb cleaner until it works freely.
