Echo PB-403T won't start
Old 04-07-12, 04:07 PM
W
Last week it was my mower, now it's my blower that won't crank. I've cleaned the carb and put new gas in, but it still won't start. When I try to crank it, it sounds like it would if I were cranking with the kill switch on. I verified the kill switch is not on and it is the correct position to run, but that's what it sounds like. Anything specific I should look at?
Old 04-07-12, 05:19 PM
P
Received 1,512 Votes on 1,359 Posts
From what you've said I would remove the spark plug and hook it back up to the spark plug wire. Make sure the tip or threads of the plug are touching the engine case and pull the cord. Do you see the spark plug sparking?
Old 04-08-12, 11:22 AM
W
The plug is sparking. I did notice, however, when I pulled it out, it was extremely black. I rubbed it with my finger and it was like it had oil on it. Anything else I can do myself before I take it to the small engine shop?
Old 04-08-12, 04:28 PM
P
Does it start with the air filter removed?
Old 04-08-12, 04:58 PM
W
No, it wont start with the air filter removed.
Old 04-08-12, 06:34 PM
cheese's Avatar
Received 94 Votes on 87 Posts
If you put a little gas into the plug hole, will it start?
Old 04-08-12, 06:36 PM
W
Just so I don't blow myself up, can you define a 'little gas' when you say to put it in the plug hole?
Old 04-08-12, 07:03 PM
cheese's Avatar
Just a dribble, like a teaspoon or two full. It won't blow you up, just put it in the plug hole, screw the plug in , and see if it will start.
Old 04-09-12, 11:38 AM
W
Put a little fuel in the plug hole, but it still wouldn't crank. Anything else?
Old 04-09-12, 01:00 PM
P
When you pull the starter cord does it feel the way you think it should? It should get tough, then easy, then tough, then easy... Do you hear any strange noises inside the engine like loose pieces of metal clanging around?
Old 04-09-12, 01:23 PM
W
Don't hear anything strange in it. It feels like it should start. It feels and sounds like I'm trying to crank it with the switch in the off position.
Old 04-09-12, 06:10 PM
cheese's Avatar
Try taking the muffler off and see if it will start, or if the exhaust port in the cylinder head is carboned up.
Old 04-10-12, 11:05 AM
W
No dice. And that all looked clean also. This just doesn't make sense to me. I had this thing cranked and running maybe 2 months ago with no trouble at all.
Old 04-10-12, 05:01 PM
cheese's Avatar
I guess at this point, I would suspect it is flooded or the plug is just bad. If it has good compression, spark at the right time, and fuel/air mixture, it should fire up.
Old 04-22-12, 03:23 PM
W
I'm gonna try a new plug this week. If that doesn't do it, then I guess it's off to the small engine shop.
