Honda HRR2168VKA
Received 0 Votes
Honda HRR2168VKA
I just bought this Honda HRR2168VKA and mowed my lawn. It is leaving a trail of grass coming from the right rear wheel? Why is it doing this? How do I fix this? Thank you.
Then you are cutting grass that is too thick or wet to mulch at one time effectively, the engine is not revved up to full throttle, you are going too fast with it, or there is a problem with the baffle plate under the mower. Mulching leaves a trail when the grass is thick, because it can only chop and re-chop those clippings so many times as more clippings are introduced and it overloads the capacity of the blade. In fact, the right side is where the clippings will accumulate and drop back to the lawn when this is the case, so with that in mind, I'm pretty sure that's the answer. The thicker it is, the slower you'll need to go. The engine should always be run at full throttle.
