Honda HR 214 push mower
shu7241's Avatar
KY
05-01-12, 06:51 PM   #1
Can't get needle valve to seat. Main question is does this mower suppose to have rubber needle valve seat? I have cleaned seat 2 times, have used grinding compound on Q-tip and used a drill bit and turned it backwards. Also bought a new needle valve. Float is good if it is proper float. The solution seems to be a rubber seat but it didn't have one when I got mower. Thanks for any help. Bill
cheese's Avatar
GA
05-01-12, 10:37 PM   #2
I believe it has a rubber tipped needle, right? If so, it should have a brass seat. Grinding compound is much too abrasive on the seat, and it may have caused problems. Try some rubbing compound on the q-tip in the drill to polish it up and see if that helps. You can buy rubbing compound in the car wax department of most stores.
"Who is John Galt?" - Ayn Rand (Atlas Shrugged)
God bless!
shu7241's Avatar
KY
05-07-12, 03:35 AM   #3
hr 214
Mr. Cheese,
Thanks very much for info on rubbing compound. I used it to clean seat and so far the needle valve is seating. Thanks again for taking the time to help. Interesting name. Bill
cheese's Avatar
GA
05-07-12, 10:15 AM   #4
Great! Glad to help. The name is a nickname I picked up back when I worked at the local Dodge dealership.
God bless!
