Mantis Tiller
Old 05-02-12, 12:38 PM
B
Mantis Tiller
I have a Mantis Tiller and I can't get it started. I have changed the Spark Plug, Changed the air filter and checked the on/off switch Wiring. Does anyone have an Idea?
Old 05-02-12, 12:46 PM
B
mantis tiller
Do you have spark at the plug? If so can you put a little gas in the carb and will it run?
Old 05-02-12, 12:52 PM
B
Yes Spark at the Plug and already tried the gas bit
Old 05-02-12, 01:08 PM
B
mantis
Well, i think those are 2 cycle engines on them so the only thing left is compression. Is that an older model? 2 cycle engines should have at 125 lbs to run or at least that's what i've found in my experiences with them.I would check that also. Do you at least get a pop or anything with the gas trick?
Old 05-02-12, 01:21 PM
B
No pop at all, Do you maybe Think it may be a clogged gas filter inside the gas tank?
Old 05-04-12, 07:43 AM
B
Sorry it took so long. It could be a clogged filter but putting gas in it should at least give you a pop or something. when you pull on the rope does it seem to have any kind of drag to it, like there is compression? Also look in the cylinder ( pull the plug out) and see if the piston is moving?
Old 05-04-12, 06:46 PM
cheese's Avatar
Received 141 Upvotes on 130 Posts
Is the exhaust clogged? Is the spark plug wet? Does the engine have compression?
