Help with Craftsman Tractor..(Chargeing issues)
Old 05-11-12, 04:53 PM
I have a 17hp Craftsman mower #917270711 and its not charging the battery when its running. I have checked the voltage at the battery when the mower is off and i have 12.9/13.0 volts. And its the same when its at full throttle. It has a red and a black wire comming from the engine that connects to the wireing harness so i checked the red for voltage and got about 8v when the key is on and the same when the engine is at full throttle But when its running i can turn on the headlights and they work fine. And they dim down to nothing when i throttle down the engine and back to bright when i go full throttle..So wouldnt that mean that the Alternator is working? and i thought the red wire from the engine when running full was to have 14v or so? I dont know whats going on with it..
Thank's for your input...
Old 05-12-12, 11:15 AM
cheese's Avatar
The lights work off of a different winding on the alternator. It sounds to me like the alternator is bad, or a magnet has come loose from the underside of the flywheel.
Old 05-13-12, 04:35 PM
Ahh ok, the alternator is under the flywheel?
Old 05-13-12, 08:19 PM
cheese's Avatar
Yep, it's under the flywheel.
Old 05-14-12, 04:35 AM
Thank's Cheese..
Looking into getting a new Alt. for it...
Old 05-14-12, 09:10 AM
cheese's Avatar
I'd take a look at it first, in case it's loose magnets on the flywheel or something.
Old 05-14-12, 04:05 PM
Thank's i will look at it first before buying a new one.....
Trackbacks are On
Pingbacks are On
Refbacks are On
