Craftsman 6.0 hp self propelled won't stay running.
Hi everybody,
Mower #917372860 with engine 143956000 and composite carb (plastic bowl.)
Friend had it sitting for 2 years outside. I got the spark working and cleaned out the carb completely. Won't stay running, unless I tilt the mower on it's right side, then it will run. I suspect a lean condition. Is there a float adjustment?
I am willing to get the bowl assy. but would like to not.
Also, when running the throttle doesn't seem to make any difference in the rpms. I can move it almost all the way to slow, and then it will stall. (It did run for a few minutes once.)
(what is a Trackback?)
Thanks in advance..
Thanks in advance..
There is no float adjustment. Typically, a lean condition on these is caused by the tiny o-ring behind the main jet. The main jet is behind the drain plug, behind a spring. Pull the jet out and look down in the hole it came out of. There will be a tiny black o-ring down there that is most likely the problem. They swell up and deteriorate, closing off the hole.
Thanks, I will give it a look. I took the jet out to clean it, but I left the o-ring in there, because I didn't know it was there. I hope I didn't blow it out and lose it. I guess if it's damaged or swollen, it's moot.
Thanks. If it's missing or bad, I'm just going to buy the bowl assembly.
