Toro model 20066
Old 05-23-12, 10:15 AM
D
Toro model 20066
My Toro 20066 push mower started running rough. It will start fine but the engine revs up then slows down and keeps doing this until it stops. At that time it wont start right up until it sits awhile. Any thoughts??
Old 05-23-12, 10:42 AM
G
Hard to tell without more info, most likely a fuel/air mixture problem of some sort. I would start easy and clean the carburetor and replace/clean the air filter.
Old 05-23-12, 04:42 PM
cheese's Avatar
Received 121 Upvotes on 111 Posts
Yep, the carburetor needs cleaning.
Old 05-23-12, 04:46 PM
G
Received 24 Upvotes on 23 Posts
I think the bowl nut is the main jet on that carb, remove the bowl, clean out any gunk you find, clean the jet, has a hole across the bottom and one down through the center, reassemble, hopefully you will be good to go. Have a good one. Geo
