weedeater featherlite fl 21
Old 06-02-12, 11:16 AM
K
i changed the fuel lines and i tried swithing them around but i'm not sure if i have then on right..the primer bulb won't inflate after i press it.. any ideas? please help
Old 06-02-12, 01:09 PM
G
Received 24 Upvotes on 23 Posts
Here is a pic of the routing(borrowed) for Poulan/Weedeater. Have a good one. Geo
[ATTACH=CONFIG]892[/ATTACH]
Old 06-02-12, 02:55 PM
K
ty for that but my set up has 2 lines coming from the fuel tank to the carb and the primer buld is connected to that...i have a weedeater featherlite fl 21
Old 06-02-12, 08:57 PM
cheese's Avatar
Received 120 Upvotes on 110 Posts
The line with the fuel filter on the end goes to the small fitting on the carb, the other line to the other fitting.
Old 06-02-12, 09:23 PM
hopkinsr2's Avatar
If The primer still won't work after routing the lines properly, Your going to need to remove,,, completly clean the carb & install a carb rebuild kit.. The carb has issues & if you open it up,, don't try to use the old parts,,, Kits are only ~$10 bucks,, Money well spent...
Roger
Old 06-03-12, 04:56 PM
K
tyvm for the advice, it really helped
