Brute Pressure Washer Problem
My neighbor gave me his Brute Model 020301 Rev 02 power washer because it didn't work correctly. He said he thought a screw was missing from the bottom. I checked and there were no missing parts. I read the other recent posting about brute pressure washer and my problem my be similar to that one but would like some guidance. My neighbor complained of low pressure or no water to the wand.
When I started it and it would burst with high pressure and then the pressure would lower. If i shut it down and left the hose on it would have more pressure when pressing the trigger and not running than when running. Run pressure starts high and then gets weaker. There are no leaks. Any suggestions would be appreciated.
Thanks
Thanks
Sorry it took me so long to respond. I have been out of town with work and have had an opportunity to look at it until now. With it running the supply hose to the gun does soften a bit. If I stop the gun from spraying it's hose gets hard as a rock and barely bends. Once the gun is discharing the hose softens and can be bent and squeezed.
Hopefully that gives you an idea.
I suppose the inlet screen could be clogged, or something could be restricted in the inlet pipe, or there could be a regulator problem if this has one.
