honda gcv160 mower,rpm problem
Old 06-11-12, 06:31 AM
I have a honda self propelled hrr2163tda mower with the gcv160 eng.This spring the rpm's started to rise and fall with the mower moving or not moving.At first I thought maybe the carb was plugged up so I removed it,soaked it in cleaner and reinstalled it with new gaskets.It ran better but the rpm problem was still there.Then after doing some research on line I replaced the spark plug ,again no improvement.I have found that if I force the govenor link to remain stationary that it will idle smooth.I have given the govenor link and springs a very close inspection and they all appear fine.I am certain I reattached it correctly to the carb when I removed it for cleaning.I feel like I've checked everything with no improvement but I must be missing something.Any ideas?
Old 06-11-12, 08:26 AM
C
Mine does that when the air filter needs cleaning.
Old 06-11-12, 09:00 AM
P
Received 1,953 Upvotes on 1,749 Posts
I would try cleaning carburetor again. This time disassembling it to better clean the internal passages & jets.
Old 06-12-12, 05:39 AM
Soaked the carb overnight in a parts washer.Its running fine now.Thank you
