16 hp briggs on simpicity mower
gbpack1950's Avatar
WI
06-14-12, 07:58 PM   #1
When starting engine motor doesn't want to turn over. Like a dead battery but it does start. Had to replace starter gear.When it does start blows blue smoke for awhile. Then seems fine. model 303777
cheese's Avatar
GA
06-14-12, 09:36 PM   #2
Sounds like gas is leaking from the carburetor while it is sitting. Does the oil smell like gas?
"Who is John Galt?" - Ayn Rand (Atlas Shrugged)
God bless!
gbpack1950's Avatar
WI
06-15-12, 05:59 PM   #3
It does have a faint gas smell. but I can't smell very good. The oil does go down as I check it per cutting.Wouldn't it be adding oil to it instead. What causes it to leak from the carb.Maybe I should just fix that to start
cheese's Avatar
GA
06-15-12, 07:38 PM   #4
Yes, generally if gas is leaking into the oil, it will raise the oil level, but it also thins the oil really badly, so it will use the oil pretty fast and you'll then have to add oil. Is the oil thin? If the carb is leaking gas, it will be needing a cleaning, new needle, and if it's a nikki carb, it will also need a gasket set. If the carb isn't leaking and the oil isn't thin, then check your valve adjustments. This wouldn't be a bad idea anyway if you haven't adjusted them in a few years... it's normal required maintenance.
God bless!
gbpack1950's Avatar
WI
06-16-12, 09:05 PM   #5
Thanks cheese I never adjusted them. Do you know what the settings are
cheese's Avatar
GA
06-16-12, 10:49 PM   #6
Set them both to .005" and you'll be fine.
God bless!
gbpack1950's Avatar
WI
06-18-12, 07:43 PM   #7
Cheese I thought I knew how to adjust the valves but I don't think I did it right
cheese's Avatar
GA
06-18-12, 09:25 PM   #8
Set the engine to 1/4" past TDC and set them in that position.
God bless!
gbpack1950's Avatar
WI
06-19-12, 07:26 PM   #9
cheese I adjusted the valves by taking out the plug sticking a screw driver in the hole until the piston just started down then adjusted. When I started the mower it ran for awhile then lost power.I opened the cover on the left side and both push rod fell out of place. Put them back in place started the engine same thing happened. What am I doing wrong
cheese's Avatar
GA
06-19-12, 09:19 PM   #10
You've got them too loose apparently. If they were that loose, the tappet from the top of the valve probably fell off too.
God bless!
gbpack1950's Avatar
WI
06-20-12, 07:08 PM   #11
Just wanted to let you know that I got. thanks cheese
cheese's Avatar
GA
06-20-12, 07:36 PM   #12
Great! An that fixed the starting problem? Glad to help.
God bless!
38racing's Avatar
CANADA
06-20-12, 08:39 PM   #13
are you torquing the set screws to the correct value?
gbpack1950's Avatar
WI
06-22-12, 04:41 PM   #14
Ok now you lost me. I seen that they are to be torq to 45lb.
cheese's Avatar
GA
06-22-12, 08:47 PM   #15
The torque is not critical, other than making sure it is tight enough to not come loose again.
God bless!
gbpack1950's Avatar
WI
06-24-12, 08:34 PM   #16
Hi cheese what is the torque suppose to be
