Mantis 2 cycle tiller - no fuel from gas tank
Received 0 Votes
Replaced fuel line and fuel filter and still get no fuel out of line. Removed gas cap to see if it would flow and still no fuel.
tested for fuel with fuel line removed from carb and still nothing.
Received 0 Votes
Fuel is now flowing. Guess it just takes a while to begin to flow through new fuel filter. Still not starting. Must have put something in wrong when I did the carb rebuild. Will give it another shot.
Received 0 Votes
It does not have a primer it is realy old. Opened it up and it clearly is flooded. When I changed the hose the replacement I put on is a bit larger. My guess is that the fuel is flowing faster than the carb is designed for.
I will put the correct hose and see if this improves.
It did rumble then stoppped immediately.
Received 0 Votes
Yes.
I pulled the air filter and it is filthy. Does not look like it is even a proper filter, looks like the previous owner fabricated it.
I will order the correct filter to see if this helps. Read other posts that said this could contribute to stall out under load.
Received 0 Votes
Got it running at a good idle and accelerating BUT then a new problem! The kill switch is dead and I couldn't shut it off without closing the adjusting screws.
I have a spare coil. Should I swap it out before buying a new switch?
Received 0 Votes
Tried the adjustments to the high and low speed screws I read in other posts. I can close the high speed screw all the way and the tiller still runs.
noticed today that the insulator (piece between carb and engine) is cracked. Repair shop says this will impact performance and may be related to stalling problem .
Hard part to find so I tried sealing the crack with some epoxy. Hopefully this will hold and close the air leak.
