Small B&S engine piston seized up
I have a Briggs and Stratton high pressure washer that seized up during normal operation. Afterwards I could not turn the engine by pulling the cord, even after removing the spark plug. I disassembled the engine, and the problem is the friction between the piston and cylinder wall. I was able to knock the piston out of the cylinder with a piece of wood. I cannot see any cause for this high friction.
Can I save my engine by taking away the high friction between the cylinder wall and piston?
sunnyflorida
Hello sunnyflorida,
If you don't see a cause for this high friction how can you take it away ?
These engines are cheap enough, It really doesn't pay to go that deep into them. I'd go along with mowerdude and find a new replacement engine, Then you'd have a warranty and longer lasting machine.
Good Luck
I would still like to know what caused the engine to freeze. Did I do something wrong? The engine stopped suddenly without warning.
What are some of the common causes of extremely high piston friction?
