VT
07-06-12, 02:56 AM
Log Splitter Hydraulics
I'm having a problem with my splitter in warm weather. It will start splitting fine, then after a while it will just stop. The enginge doesn't stall, it just pushes the wood as far as the wedge and won't go any farther. If I leave it for a few hours it will start splitting again, and it splits fine in cooler temps. Any ideas?
IA
07-06-12, 04:40 AM
That's typical of a worn pump. The oil thickens with cooling and the pump works better. You can try a viscosity booster. Something like Trans X for automatic transmissions may help. It swells worn seals and beefs up the viscosity a little.
If it comes down to the last breath on it you can throw STP at it. That's, for the most part, a motor oil additive, but blends with hydraulic oil. It will thicken things up substantially.
