Help please - Power Washer
Old 07-09-12, 04:03 PM
mr_sma_jr's Avatar
My power washer will not start... Push the prime bulb 3-4 times and it runs for a split second (prime bulb gas)... I swapped out the carb abd gas tank and got the same results... Is it internal to the engine or something I can "semi-easy" fix ??? My washer is a Craftsman, 3.75HP, 1500PSI. MOdel# 580.768000...
Thank you
Old 07-09-12, 04:12 PM
G
Received 28 Upvotes on 27 Posts
You need to install a new diaphram kit, it is Briggs part # 795083 or old # 495770 also Lowe's has a kit #5083 which has the same parts.
Here we go:
Remove air cleaner, there are 2 bolts that hold things together, one on the front of the tank 3/8" and one into the block 1/2", remove these bolts, now "slowly" slide the carb/tank off the intake tube and breather tube, now tilt the tank in to release the throttle linkage and waalaa the carb/tank is removed. Check the intake tube to see if the “O” ring seal and plastic retainer are still on the intake tube, if so remove them and re-install them into the carb. Remove the 5 screws from the carb/tank remove carb(don't loose the spring) now spray all holes, cracks and crevases in both the carb and tank surface with brake parts cleaner, remove the main screen(looks like a thimble), now with a small screwdriver pry out the main jet(carefully) and clean it, check the “O” ring on the main jet for damage, if it is damaged it must be replaced, reinstall the jet, it can be difficult some times to get it to snap back in place(I use the rounded end of a screwdriver handle). Remove and clean the fuel pickup stem(not necessary if the fuel tank was clean). Clean any junk/rust from the tank. Install the diaphram on the tank then the gasket(no goo or sealer) now carefully replace the carb(the spring will try to misalign the diaphram), tighten all screws a little at a time so as not to crimp the diaphram until they are all tight. Install the carb/tank in reverse order and you are done. If I missed something one of the real mechanics will correct me. Have a good one. Geo
Old 07-10-12, 09:46 AM
mr_sma_jr's Avatar
I replaced the carb and gas tank from a known good engine (another lawnmower) and got the same results, only burning the primer bulb gas... I will replace the diapharm but it should be good... Is there anything else I can try ???
Old 07-10-12, 09:50 AM
cheese's Avatar
Received 131 Upvotes on 121 Posts
there is a plastic tube that the carburetor pushes on to. Check to see if it is loose. Otherwise, it seems to be a carb problem.
Old 07-15-12, 11:24 AM
mr_sma_jr's Avatar
Thank You
I bough and installed new diaphram, spring, and filter... Works great... Guess I should have bought two because the other carb/tamk assy didn't work either,,, Maybe next month... Thanks again !!!
Old 07-15-12, 03:57 PM
G
Success is a wonderful sound. Have a good one. Geo
